Block attribute rotation
Hi, I've created dynamic block of shaft with attribute description which can be moved away from shaft (works fine). The problem I'm having is when I want to rotate whole block - attribute description rotates different from other parts. I've noticed this happens only when I'm selecting everything under Rotate action selection, when I'm not selecting Polar Stretch and Move action attribute description rotates OK but then I can not move it properly. Please help.
ojuris
hi
why you need point parameter?
you can move attribute with polar parameter - see attached
or you need attribute always horizontal?
P.S.
it is better always create your block 0,0 coordinates
ojuris
may be you need attribute always horizontal
Point parameter is not essential, problem is in my understanding of dynamic block actions. Attribute must be aligned with shaft inlet so yours solution is the one I've been looking for. Thank you very much!
ojuris
often problems come from chained parameters
In your block you have chained point parameter. When you use rotation then you rotate attribute and also rotate chained point parameter who move attribute and this moveing in this moment you don't need
