So I have a block that represents a aluminum composite modules of 1x1, I want to array them in a way that they wil grow in a triangular shape, on the image below i show a representation of how i would like the block to work (i justa created the block and put rando anctions on the paremeters to give a better representation of how i want the block to work). So the drawing on the left is how i want the block to start, and the draing on the right show how I ant it to grow. Basicaly the grip on the inferior right vertex should array the square object and and a new row of squares after 3 copies of the initial square, plus, this grip should create a array of the three different cutted squares on the bottom. The uper grip shoul just array the rows of the initial square.
Is something like that possible to do?
below i attached the file with my drawings
e,
Hello @jppinhovilela
You can use the hatch inside the boundary and set the scale to match with your requirement and add a scale parameter to scale the block. See attached.
