Array distance
Array distance
Message 1 of 8
Array distance
Hi, there.
I am trying to draw a array of squares and would like to add an increment to the spacing between the squares. For example, the distance from the 2nd square to the 1st square would be 2 and then distance from the 3rd to the 2nd square would be 2.5 and so on. Can someone please shed some lights on how this can be done? I am pretty new to AutoCad.
Thank you very much.
James
Replies (7)
Message 2 of 8
Libbya
A varied column or row offset is not an array.
Are you working with a set number of squares?  A set range?  More specifics about what you are trying to do might get you a reasonable solution.
Message 3 of 8
I am trying to draw a set of squares where the distance between the squares increases linearly between each adjacent square.
Message 4 of 8
So, it appears that it is not a straightforward thing to do. Just surprised it wasn't simpler than this to do this.
Message 5 of 8
Libbya
It may or may not be straightforward, but you didn't answer either of my two questions so I cannot say.  Are we talking about 1-10 squares, 1-100, 10-Infinity?
Message 6 of 8
I am hoping to draw around 1500 10-micron squares in the x direction with increasing spacing, the maximum distance between the first and last square is no bigger than 30mm.
I am hoping to change the increment in the spacing between the squares thus changing the number of squares I can fit into a 30mm length.
Thanks.
Message 7 of 8
Libbya
That would not be straightforward in any way with which I am familiar in dynamic blocks or stock AutoCAD.  I believe a lisp routine could accomplish it fairly easily.  You might inquire on that forum for better results.
Message 8 of 8
Okay, Thanks for the help.
