Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day everyone!
Is it possible to link the distance of an array action to the distance of a scale action? Example: The attached batt insulation block. I want to be able to insert the block and grab the scale grip and scale the block to fit the cavity it is being used for. Then, I can grab the grip for the array and make it fill the length of the cavity. This works well if I do it in the reverse order, but not in the order I'd prefer. Also, if I do it in the order that does work and then I go back and mess with it again (say the cavity got larger or shorter), then it seems to get all out of wack.
Thanks in advance,
