Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello folks. I've got a line in a block that connects two objects which can more with respect to one another via a Stretch Action. This line is diagonal so its angle changes as you drag the two objects further/closer. I'd like to set up an Array Action along this line and always have the array parallel to said line - is there a way to set this array up so it will change angle with the diagonal line? Thank you!
