Lookup Rotation Attributes
Hello guys, how would I apply a search to rotate the attributes present in my multisense block.
(image and .dwg with example)
If anyone can create a sreeencast shown step by step, I will be very grateful!
Libbya
It is easy to do 'original' and 'above' but 'left' and 'right' are problematic because your TAM/RES attribute is justified to the center.  When the attribute is changed to a different length, then the rectangular design will not move with it.  That will make the space between text and design larger or smaller.  There is not a way to automatically move the design based on the length of the attribute text.
Attaching a screencast and example of how the block should behave, but I don't know how to create it this way.
Libbya
This shows how to do what you are asking and also shows the issue I described in my last post.  You can obviously use as many point/moves as you like and move them to whatever coordinates you like using the lookup table.  Hope that helps.
@Libbya  Got it well !!
I will try to replicate !! Thank you!
