Area Block Malfunction ....
jim3thornton
jim3thornton
I am trying to create a dynamic block that included multiple attributes, a dimensions that will illustrate length and width, and a field that will list the area...
The goal would be that the data would remain in the center ....
Through trial and error I've gotten to this point ....
Besides the attribute not being in the middle ... the dimensions are now not working and I would like to get the grips to stay on the upper right corner of the rectangle ... and input would be helpful
Libbya
Hope this helps.
jim3thornton
I got it to work ...
I noticed that you "reassoicated" the dimension strings to the rectangle ... a command I've never used before ...
So now that I got it to work ... is it possible to moved any of the individual lies of the attributes that have been moved to the center?
That was 2 cents from my co-worker ...
Libbya
Sure, you can move the attributes.
jim3thornton
Mission Accomplished .... see attached
jim3thornton
