Annotative text clash
 I have a plan that I'm using to create a series of 'You are Here' maps for a building, which I need to rotate so that maps in every location are heads-up. I've added the room names and codes as annotative text in model space, but when I rotate the viewport in paperspace the names overrun and clash with one another.
Is there a way to avoid this? And if not, is it possible to move annotative text in one layout, without it affecting the others?
Any help would be much appreciated!
Libbya
Post your file with any inquiry.  Are you using Dynamic Blocks?  If not, then this is not a dynamic blocks issue and you are posting to the wrong forum.
