I need to show an angle measurement in a block which will measure with rotating parameter. Actually its working but since the block rotating more than 180 deg, the showing in reverse direction. i need to show the angle measurement always in clockwise direction. may i get any advice??
I have a block with the same issue, I want my north arrow to measure clockwise starting north at 0 degrees. Currently, the maximum angle it measures is 180 degrees. I would like its maximum angle to 359 degrees, so for example it would read 270 degrees when pointing to the left, as of right now it reads 90 degrees when pointing to the left.
