Anchor Bolt
Anchor Bolt
Jonathan3891
Advisor Advisor
Anchor Bolt
Jonathan3891
I am having a hard time getting this dynamic block to work like I want.
If I change anything I have to redo all the actions for some reason.
I have 3 visibility sets:
AB-1
AB-2
AB-Hide Embed
I want the projection (the distance from the bottom of the washer to the top of the bolt) to remain the same for all the three visibilities.
I can show the linear stretch action for all three visibilities, but the selection set wont show?
I need the threads at the top to array when I stretch the bolt.
I cant get this part to work at all. The array action is acting crazy when I insert the block.
I'd appreaciate any help!
DSM_Dude
Jonathan Norton
Blog | Linkedin
ojuris
if I correctly understand your problem I have question - why you need 3 linear parameters, one for each visibility?
see attachment
Libbya
Here's how I'd make the array work.
Jonathan3891
Libbya, can you save that down so I can open it in 2012?
I can not install dwg true view on my machine at work so I have no way of doing it myself.
Jonathan Norton
Blog | Linkedin
Jonathan3891
Thanks Ojuris, the parameters work as they should.
I was having trouble getting it to work like I needed. I only wanted 2 linear parameters, but I couldn't get distance 1 to work with each visibility. I have no idea what I was doing wrong.
Jonathan Norton
Blog | Linkedin
ojuris
here is Libbya file in 2010 version
