Adding values to dynamic block
Hi all,
I've created a very simple block with an XY Parameter and an Array Action. Works perfectly fine, but there is something i want to add, but i can't figure out how to do it..
What I want, is to add a attribute with the name: Panel 1. If I stretch (array) this "panel" it needs to automaticly change the name to Panel 2, Panel 3 etc.
Is this possible to do, and if it is, how do I do this?
Thanks in advance.
I've attached my Panel block
ojuris
For example try this
Don't forget use Regen after stretching the block
Well, it sort of does what i want it to do.. But i only want to see panel 1 or panel 2.. Not the X1 or Y1.
Did you work with fields? Or can you explain how you did this?
More difficult is: If i'm going up on the Y axis, from 1 to 5 for example, and I add a second row on the X axis, it needs to continue from 6 to 10..
See the image i've attached how i want the end result to be.. Is there a way how to do this?
ojuris
Yes I work with fields. You can't array attribute because each attribute in block must have unique name. In block I add another block (consists from 1 attribute) and arrayed that block. And in that block's attribute I use fields with folmulas.
Try new version
Perfect!
But what option did you use with the field? Can you make a screencast with the explanation?
Thank you for this perfect solution!
ojuris
