hello everyone, I made a block out of a rectangle, but i need to move it arround from more than the based point
Solved by Libbya. Go to Solution.
As I said, you can add as many point parameters with move actions as you want. Each point parameter with move action will add a grip point to the block in just the way you describe.
Open the 'Block Authoring Palette', go to the 'paramters' tab, click on 'point' and place it anywhere in your block. Go to the 'actions' tab and click 'move'. Select the 'point' parameter you just added. Right-click the 'move' action you just added and select 'action selection set' and 'new selection set'. Select everything in the block except any other dynamic actions.
This is the absolute most basic thing to do in a dynamic block. You may want to go to youtube and watch a couple free dynamic block tutorials.
See the attached file.
i see you added a base point to the block to make it move with the other grips, which solves my problem... thanks so much
I have a simmilar problem but more complicated... I can add a grip point with the move but my block has other actions as well and I'd like them to move toghether... for example the rotate action, when I rotate the block using the rotation parameter and the move the block with the new gripp, al the parameter grips move from their original place and all the actions are off place!
please help me with that!
(attatched the block)
hi!
always carefully add actions in other actions - only when you really need it
in your block you don't need add flip and move actions in rotate action - that was problem
