Actions on both grips?
No aplicable
926 Vistas
7 Respuestas
Mensaje 1 de 8
No aplicable
I'm sure that the answer to this is probably a no, but is it possible to get a move action to work on both parameter grips on a linear parameter? Is there a work around for this? I'm starting to get sick of doing the same stretch and move actions on both sides.
If the answer is a no does anybody have a suggestion as to where to post this idea on the ideas board? There's seems to be no board for it
0 Me gusta
Soluciones aceptadas (1)
927 Vistas
7 Respuestas
Respuestas (7)
Mensaje 2 de 8
Libbya
Nope.  Grips are associated with one end of the linear/polar parameters only.
I think that being able to associate an action with more than one grip would make troubleshooting much more challenging.  I do wish that one could modify actions to change which grip location it is associated with.
0 Me gusta
Mensaje 3 de 8
No aplicable
Yeah if you could copy and paste the actions and keep the properties and selected objects that would be perfect. Just re associate the actions to a new grip. It would be a huge time saver. What idea board do you think would be best to share this on?
0 Me gusta
Mensaje 4 de 8
MMcCall402
In your post you mention "the same stretch and move actions on both sides", could you explain this a little more?   I ask because I'm wondering if this might be a matter of using two move/stretch actions on just one of the grips with the move/stretch actions set up to operate in opposite directions.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
0 Me gusta
Mensaje 5 de 8
No aplicable
Your suggestion would work. You could also set them to stretch and move from the middle point of a linear parameter instead of the starting point. But then you have to place the block in reference to its middle point. For my use I prefer stretching from one side which is why I can't use your suggestion. Thank you though!
0 Me gusta
Mensaje 6 de 8
h_s_walker
You don't have to have the middle of the block at 0. You can add a basepoint parameter, or not. See the attached drawing
Howard Walker
Left Handed and Proud
0 Me gusta
Mensaje 7 de 8
No aplicable
I know this but thank you anyway! For my intended  use it's more ideal to stretch from one side of the block to the other. With your suggestion I would have to place the block in the correct middle point to stretch to the right size.
0 Me gusta
Mensaje 8 de 8
No aplicable
Solución aceptada
If you would also like to see a feature like this built into block editor mode please go vote for the idea that I shared on the Idea Board under Community since there is no place for just plain vanilla Auto Cad.
https://forums.autodesk.com/t5/community-ideas/copy-actions-in-block-editor/idi-p/8113637
0 Me gusta
