good day,
Can you help me, i am trying to create a 3D foundation detail for a Sign which is adjustable with the dimensions for each sign to give a more realistic appearance. I have attached a clip of a typica example and a drawing of my first attempt. My attempt seems to work in one plane but on another two of the 4 lines move rather than stretch when stretched.
Any help appreciated.
Regards
Colin
Solved by ojuris. Go to Solution.
you have problem with stretch action frame size (what parts of lines are in and what aren't in)
to stretch the line - only 1 end of line must be in stretch frame
in your block it can't be done with 1 stretch action - I add 1 more action
