Dynamic block parameter having the same value as block's atrubute.
Hey. I created a dynamic door block with dynamic door width. I can either stretch it with any possible value or fix some values. I would like however to add an attribute to the block named "D-WIDTH" for example. Then, I would like the DOOR WIDTH parameter to have the same absolute value as the D-WIDTH attribute. Any clues how to do that?
m_rogoff
Type FIELD then follow the attached pic.
Select "Object"
Hit the button at the top middle (red arrow) and select the "Door Width" linear parameter
Then select "Distance"
Fields (you'll see a gray box around the text, won't print) will automatically update when you refresh, plot or save
I'm afraid you did not understand what I'm trying to do. I dont want to display the door with. I want the dor width to get the value of a block attribute,
Charles_Shade
Will not work that way.
An Attrib cannot drive a Parameter
