You're not alone. I, too, am having trouble with the new release.
"Rick Mattingly" wrote in message
news:1015878.1097859035878.JavaMail.jive@jiveforum1.autodesk.com...
> Thanks for the assist Ben. Unfortunately, I cannot post the problem file.
We are a public utility and the file in question is our distribution system
mapping. The file is very large and there is also a security issue with
posting it.
> However, your comment brought to mind that I should check the new viewer
release with a different, smaller file from the same source. I did this and
the 'Print to Page' feature worked correctly for this smaller file! It would
appear then that the problem has to do with either the size of the problem
file or some attribute within the file that the Print to Page feature does
not like. The Print to Page option worked fine on the same large file with
the previous release though.
