- Mute
- Permalink
- Report
This is seriously, SERIOUSLY lame.... If I try to define a dimension in terms of other dimensions... I can't. Here's a trivial example: Put one rectangle, with dimensions d1= 1.0 and d2 = 2.0, inside another, larger rectangle, with dimensions d3 = 3.0 ans d4 = 4.0. Now try to center the smaller rectangle vertically within the larger one, by defining an equation for the distance between the bottoms of the two rectangles, based on d1 and d3. It SHOULD be possibly to reference d2 and d3 by simply clicking on them, and their names should be transferred to the dimension textbox. But that is not what happens....
This is incredibly basic functionality that I use CONSTANTLY, and works perfectly in Solidworks.
Ray
