I am trying to design a manifold. It has a flange and 4 pipes.
I created the flange and then created the curved lines to the dimension I needed to start with. Of the 4 pipes there are are 2 pairs of the same pipes.
I have some questions regarding the finished pipe after lofting.
I need the 4 pipes to all be the exact same length (which is fine at the moment as I have duplicated all 4 pipes), however I need to then align the pipes such that the 4 open ends of the pipes all meet at a specific point. The issue I have is that I need both pairs of pipes need to be the same length when they meet but both pairs will follow a slightly different path so as to not contact each other.
Is there a way to fix the total length of the lines I have used so that I could manipulate one pair to get them to fit without contacting the other pair knowing they will remain the same length?
Appreciate any help on this.
