Fusion360 doesnt start properly
KirillChepizhko
Message 1 of 27
KirillChepizhko
What is happening ?
When I close all those and get to the main UI my dashboard is gone.
Replies (26)
Message 21 of 27
KirillChepizhko
Ever since I rolled back to 355.98 I have  not experienced the issue !
Message 22 of 27
I'm having this same issue.
Been using Fusion 360 since Feb 2016 with no issues, designed some furnature, used the program as recently as ~ 3 days ago. This morning, I'm getting the same AdCefWebBrowser.exe error as noted in the first post.
Windows 7 x64 Home Premium
nVidia GTX 680 driver 364.51
Complete error is listed below:
Problem signature:
Problem Event Name: APPCRASH
Application Name: AdCefWebBrowser.exe
Application Version: 19.1.18.0
Application Timestamp: 5630dcd9
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.19160
Fault Module Timestamp: 56bcd74c
Exception Code: c0000005
Exception Offset: 000000000004a604
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 191d
Additional Information 2: 191d513b76503f2b28cda14cdc9b4fd9
Additional Information 3: ae7a
Additional Information 4: ae7aa22b469aebe1fd8db0bbe89e65ee
Starting at post #2, after restoring defaults and clearing user cache, this is the general sequence of events:
1) Open Fusion 360 - error message appears, program loads with no access to files.
2) Assume preference defaults have been reset and remain reset (because after resetting them once there is no option to do it again because I haven't changed any preferences).
3) Clear data cache restarts the program. When program restarts everything works. (Sometimes it is required to do this several times in a row before Fusion 360 starts without error)
4) Now that Fusion 360 is running correctly, close Fusion 360.
5) Start Fusion 360 again and repeat from step 1. (Except that sometimes I may be able to start Fusion 360 without error several times in a row before seeing the error again).
All I can comfortably say with regard to an established pattern is the following:
1 - I've seen it take up to 3 clear cache restarts in a row before things work correctly.
2 - after Fusion 360 opens up without an error, I've been able to close and re-start it normally up to 6 times before the error returns.
Needless to say, I've not changed any network settings this morning, nor in the past several weeks, nor have I changed Windows Firewall, which is the only firewall software present on the machine.
Jumping ahead, I went ahead and rolled back to nvidia driver 355.98. However, in my case, the issue persists with no discernable changes.
Message 23 of 27
innovatenate
Autodesk Support
Autodesk Support
In the previous case, there was a conflict with the specific graphics driver that was being used. It may help to uninstall all previous occurences of graphics drivers and then re-install version  355.98.
If you haven't done so yet, it may also help to try clean uninstall of Fusion 360. Afer unisntallilng, install a "fresh" version from the Autodesk website.
I hope that helps!
Nathan Chandler
Principal Specialist
Message 24 of 27
Mr. Chandler,
If you read my post, nvidia driver 355.98 didn't solve the problem.
As for uninstalling and reinstalling, I notice that I can no longer download the latest version of Fusion 360 because I'm being asked for an educational profile, yey I've been out of school for a decade and am using the software as a hobbyist.
Anyway, after uninstalling and reinstalling (using the installer I'd downloaded previously) the issue persists.  I can eventually connect properly and access my saved files by clearing user cache usually between 1-3 times.
Message 25 of 27
innovatenate
Autodesk Support
Autodesk Support
In another case, I requested a user start up in safe mode and eliminate some of the background processes that were running. In this case, the user received the below error message after starting Fusion 360, followed by a blank data panel.
The browser process exits unexpectedly. Please check:
1) You have internet connection;
2) Firewall blocks starting the browser process AdCefBrowser.exe;
3) Firewall blocks browser process AdCefBrowser.exe to access Internet;
4) Proxy setting in Preferences - > Network.
Do you want to try connecting internet again?
After eliminating the below processes, we found that Fusion 360 functioned normally.
1.. Apple Push
2. CurseClientStartup.ccip
3. Daemon Tool Lite
4. DivX Media Server
5. DivX Update
6. iTunes Helper
7. MPExtenededApplicationsServiceConfigurator
8. MPTray.exe
9. PlaysTVVideoRecorderByRaptr
10.Quick Time Task
11. Steam Client Bootstrapper
I haven't been able to confirm which process caused the conflict. Are any of the above processes running on your system? Perhaps you could run msconfig to eliminate all nonessential processes, restart and retest?
Nathan Chandler
Message 26 of 27
ruede_aeschlimann
I was having the same issue. In my case it was the EVGA Precision Software that was causing the problem. Closing the software resolved my problem.
Message 27 of 27
Thank you...closing EVGA PrecisionX worked for me as well.
