There are two symptoms:
1) The simulation no longer represents the stock based on a body, but just a plain rectangular block.
2) Tool paths that were correct earlier are now bleeding into the solid including dovetails cutting as an end mills and other issues.
Versions saved earlier today, that were simulating correctly, now have the same issues. The tool library and ops still list the correct tools. Please let me know if this is a known issue or... if you want I could email you the file and the tool library.
Thanks!
Solved by TheNewEd. Go to Solution.
