I'm hoping my question is just a case of "can't see the forest for the trees".
I'm building a spar for a center section of a wood biplane, and it has two reinforcing plates that are attached, then the assembly has an angle cut in it.
The two plates start out as the same blank, and then after assembly are cut to different shapes.
The issue I run into is when I make the cut, the cut affects both instances of the part, just like you'd expect in a part level feature.
My question? Is there a way to create an assembly level feature in Fusion 360? I tried activating the top level, but I had no luck there.
I hope I'm missing something obvious! Thanks in advance!
It is possible to fly without motors, but not without knowledge and skill.
Wilbur Wright
Wilbur Wright
