Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Interop Inventor (Shaded with Edges)
11 REPLIES 11
Message 1 of 12
alexandre
2417 Views, 11 Replies
When we create the dwg from Inventor, we have the visualization style for Shaded with Edge.
Even with the Design Review> Option> Model> Color Settings> Model Edge Color = As published
However, when we open the dwf model in Design Review, we always have the Shaded view active.
Question: Is there an Activex control to set as default in Design Review "Shaded with Edges"?
11 REPLIES 11
Message 2 of 12
dillon3
in reply to: alexandre
If I understand what you're looking for, you want to export models as DWF with the shading style as "Shaded with Edges." From what I know of Design Review, there is no specific function to set the shading style. However, if you go back to the Options > Model, you can uncheck the box "As Published" and change the color to black, which would then treat the model as if you had "Shaded with Edges" active.
Inventor, by default, will publish line colors to be as close to the material color as possible, I think.
Message 3 of 12
dillon3
in reply to: dillon3
Okay, so I found it staring me right in the face.
Message 4 of 12
alexandre
The central question is: How to default to Design Review: "Shaded with Edges" and "no lights or lights published".
Message 5 of 12
YuhanZhang
I just have a simple HTML format file which uses the ADR(Autodesk Design Review) activex control, and I tried it to set the DisplayMode to Shaded with Edges(ie.e SectionType.DisplayMode = 2), and it seems working, I share the code here:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"   "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<title>Autodesk Design Review Sample</title>
<script type="text/javascript" language="javascript">
function ListSections()
var ECompViewer = ADViewer.ECompositeViewer;
var Sections = ECompViewer.Sections;
var secList = document.getElementById("SectionList");
for (iSection = 1;(iSection <= Sections.Count); iSection++)
var Section = Sections(iSection); //Set the section to a separate object
secList.innerHTML += Section.Title + "<BR>";
var SectionType = ADViewer.ECompositeViewer.Section.SectionType;
if (SectionType.Name == 'com.autodesk.dwf.eModel')
SectionType.DisplayMode = 2;
</script>
<script type="text/javascript" for="ADViewer" event="OnEndLoadItem(bstrItemType,vData,vResult)">
if (bstrItemType == 'DOCUMENT')
//Indicates the document is finished loading
ListSections();
</script>
</head>
<body>
<div id="title"  style="position:absolute; top:0px; left:0px; width:600px;  height:100px; text-align:left; background-color:#ccc"> 		Autodesk Design Review JavaScript Sample.</br></br> 		This sample will load a file in Autodesk Design Review, once		the DWF has completed loading the ListSections() function will		list the pages found in the DWF.  </div>  <div id="canvas"  style="position:absolute; top:100px; left:0px; width:425px;  height:400px; text-align:center; background-color:#ccc">  <object id="ADViewer" 		classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" 		border="1" width="400" height="400" VIEWASTEXT>		<param name="Src" 			value="Assembly1.dwfx">		</object> </div>  <div id="SectionList"		style="position:absolute; top:100px; left:425px; width:175px; 		 height:400px; text-align:left; font-size:10pt; background-color:#ccc" > 		List of Sections:</br></br>
</div>
</body>
</html>
You can save it as a .htm file, and also you need an Assembly1.dwfx in the same folder(or you need to edit in the above code to specify the file path), then you can open the .htm file in IE, and usually there is a dialog at the bottom of IE asks if you want to unblock the activex that you need to agree, then it will show the result like below:
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 6 of 12
WHolzwarth
in reply to: YuhanZhang
Many thanks, Yuhan.
I've tried the HTM file in a common folder together with a file renamed to Assembly1.dwfx, and it worked using IE.
No output could be seen with Firefox, Opera or Chrome.
But the IE window was too small, and I didn't see a different look in ADR 14.0.0.177.
What am I missing?
Walter Holzwarth
Message 7 of 12
WHolzwarth
in reply to: WHolzwarth
Some progress now, after switching the small window to full screen.
Walter Holzwarth
Message 8 of 12
YuhanZhang
In the code you can change the width and height for the view window size in the <object> </object> tags:
As this sample is to demonstrate how the ADR ActiveX control works, you need to use a browser that supports ActiveX to run the html code, IE is the browser which natively supports ActiveX. You can also create the code in other languages(like VB.net etc.)  to work with ADR APIs.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 9 of 12
alexandre
Thanks Yuhan Zhang,
 Could you tell me which parameter and variable to adjust the "field of view".
Message 10 of 12
YuhanZhang
This can be controlled by the Camera, below is the sample html code, you can find the Camera.Field.Set to set the field point to change the field of view:
<head>
var Camera = Section.Camera;
var CurField = Camera.Field; //Get the current Field
// zoom the camera into the model.
Camera.Field.Set(80,80); //(CurField.X - 100, CurField.Y - 100);
// Set the new point to zoom in
ADViewer.ECompositeViewer.Section.Camera = Camera;  //Set the new camera
</script>
ListSections();
</script>
</head>
<body>
<div id="title"  style="position:absolute; top:0px; left:0px; width:600px;  height:100px; text-align:left; background-color:#ccc"> 		Autodesk Design Review JavaScript Sample.</br></br> 		This sample will load a file in Autodesk Design Review, once		the DWF has completed loading the ListSections() function will		list the pages found in the DWF.  </div>  <div id="canvas"  style="position:absolute; top:100px; left:0px; width:425px;  height:400px; text-align:center; background-color:#ccc">  <object id="ADViewer" 		classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" 		border="1" width="900" height="600" VIEWASTEXT>		<param name="Src" 			value="Assembly1.dwfx">		</object> </div>  <div id="SectionList"		style="position:absolute; top:100px; left:425px; width:175px; 		 height:400px; text-align:left; font-size:10pt; background-color:#ccc" > 		List of Sections:</br></br>
</div>
</body>
</html>
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 12
alexandre
Dear Yuhan Zhang,
Please have some C# example. We are having difficulty finding the class belonging to DisplayMode.
Message 12 of 12
alexandre
Dear Yuhan Zhang,
