Batch Convert DWF files to PDF
Nejc.Leban
Message 1 of 9
Nejc.Leban
Hello.
I'm looking for a way to convert a folder full of DWF files to PDF. I've been trying multiple APIs, but none of them work the way I want them to; either there's a watermark or the quality or contents of the converted PDF drawings are worse than the original DWF.
Best regards,
Nejc
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
"free" from 3rd parties always has a price.
Any reason this built-in tool is not working for you
You'll need to purchase a 3rd party tool if you need a quick fix
https://www.guthcad.com/convert-dwg-to-pdf.htm
https://www.reaconverter.com/convert/dwf_to_pdf.html
https://www.bitrecover.com/dwg/converter/
HTH
Message 3 of 9
Nejc.Leban
I have more than 100.000 files, with different sizes (A0 - A4). Using batch print wizard would take too much of my time. I've looked at reaConverter, which would convert individual dwf files to pdf, but I have certain drawings that are made up of multiple pages in separate files, let's say drawing 00001 has 3 pages - 00001_P1.dwf, 00001_P2.dwf, 00001_P3.dwf. Let's also say that each page is a different format, 00001_P1_A2.dwf, 00001_P2_A3.dwf,... I would like the pdf to be a single file with multiple pages.
That's why I would like to automate the process by making my own tool, but I would access the Design Review API which would allow me to make custom settings for converting the files.
Message 4 of 9
pendean
Community Legend
Community Legend
Thanks for sharing that information.
ADR development stopped back in the year 2017 at Autodesk: API info requires some digging to find at another website, start here https://adndevblog.typepad.com/autocad/adr-api/ nd if needed reach out to authors over there.
HTH
Message 5 of 9
Nejc.Leban
Thanks, I'll give that a try.
Message 6 of 9
sarah_masonEJTK9
Community Visitor
Community Visitor
I have used guthcad's tool however it's throwing the scale of the drawings off. Have you heard of this issue?
Message 7 of 9
minhaalex43
Community Visitor
Community Visitor
Hi there! For converting DWF files to PDF while maintaining quality, I'd recommend using one of these approaches:
  1. Using Autodesk Design Review (free):
  • Open your DWF file in Design Review
  • Go to File > Export > PDF
  • In the export settings, select high quality and ensure "Add watermark" is unchecked
  • Save the PDF
  1. Using AutoCAD (if you have a subscription):
  • Open the DWF file in AutoCAD using the "DWF Underlay" feature
  • Use the PLOT command
  • Select "PDF" as the printer/plotter
  • Configure plot settings to match your quality requirements
  • Plot to PDF
  1. Using Autodesk Revit (if you have it):
  • Import the DWF file
  • Use Print > PDF printer
  • Adjust print settings for optimal quality
  • Print to PDF
For batch processing multiple files, you can:
  • Use Design Review's command line interface (DR.exe) with a script
  • Create an AutoCAD script to automate the process
  • Use Autodesk Forge API to programmatically convert files (requires development)
The built-in Autodesk tools typically provide the best quality since they're designed specifically for DWF files. They also preserve layers, measurements, and other metadata that third-party converters might miss.
Hope this helps! Let me know if you need any clarification on the steps.
Message 8 of 9
terje5UJJ7
Observer
Observer
You may also look at ViewCompanion which can batch convert DWF files to PDF without use of any printer device.
Read more here:
https://www.softwarecompanions.com/batch-convert.html
-th
Message 9 of 9
Nejc.Leban
Thanks for replying. I've since finished converting the files using reaconverter and created an app to merge the pdf pages into a single pdf file.
