Batch Convert DWF files to PDF
Nejc.Leban
Nejc.Leban
Hello.
I'm looking for a way to convert a folder full of DWF files to PDF. I've been trying multiple APIs, but none of them work the way I want them to; either there's a watermark or the quality or contents of the converted PDF drawings are worse than the original DWF.
Best regards,
Nejc
pendean
Community Legend
Community Legend
"free" from 3rd parties always has a price.
Any reason this built-in tool is not working for you
You'll need to purchase a 3rd party tool if you need a quick fix
https://www.guthcad.com/convert-dwg-to-pdf.htm
https://www.reaconverter.com/convert/dwf_to_pdf.html
https://www.bitrecover.com/dwg/converter/
HTH
Nejc.Leban
I have more than 100.000 files, with different sizes (A0 - A4). Using batch print wizard would take too much of my time. I've looked at reaConverter, which would convert individual dwf files to pdf, but I have certain drawings that are made up of multiple pages in separate files, let's say drawing 00001 has 3 pages - 00001_P1.dwf, 00001_P2.dwf, 00001_P3.dwf. Let's also say that each page is a different format, 00001_P1_A2.dwf, 00001_P2_A3.dwf,... I would like the pdf to be a single file with multiple pages.
That's why I would like to automate the process by making my own tool, but I would access the Design Review API which would allow me to make custom settings for converting the files.
pendean
Community Legend
Community Legend
Thanks for sharing that information.
ADR development stopped back in the year 2017 at Autodesk: API info requires some digging to find at another website, start here https://adndevblog.typepad.com/autocad/adr-api/ nd if needed reach out to authors over there.
HTH
Nejc.Leban
Thanks, I'll give that a try.
sarah_masonEJTK9
Community Visitor
Community Visitor
I have used guthcad's tool however it's throwing the scale of the drawings off. Have you heard of this issue?
minhaalex43
Community Visitor
Community Visitor
Hi there! For converting DWF files to PDF while maintaining quality, I'd recommend using one of these approaches:
  1. Using Autodesk Design Review (free):
  • Open your DWF file in Design Review
  • Go to File > Export > PDF
  • In the export settings, select high quality and ensure "Add watermark" is unchecked
  • Save the PDF
  1. Using AutoCAD (if you have a subscription):
  • Open the DWF file in AutoCAD using the "DWF Underlay" feature
  • Use the PLOT command
  • Select "PDF" as the printer/plotter
  • Configure plot settings to match your quality requirements
  • Plot to PDF
  1. Using Autodesk Revit (if you have it):
  • Import the DWF file
  • Use Print > PDF printer
  • Adjust print settings for optimal quality
  • Print to PDF
For batch processing multiple files, you can:
  • Use Design Review's command line interface (DR.exe) with a script
  • Create an AutoCAD script to automate the process
  • Use Autodesk Forge API to programmatically convert files (requires development)
The built-in Autodesk tools typically provide the best quality since they're designed specifically for DWF files. They also preserve layers, measurements, and other metadata that third-party converters might miss.
Hope this helps! Let me know if you need any clarification on the steps.
