Message 1 of 16
Joint Help
- Mute
- Permalink
- Report
OK, I could use some help with joints. I think I have figured out a work around to put these two pieces together but I'm hoping there is a better way than to use the construction bodies from each of the parts.
I want the axis of the Crossmember piece to align with the axis of the hole on the front side of the leg. And I want the cope of the Crossmember piece to be tangent to the outside face of the leg. See attached images. I faked their placement by hand to convey what I am trying to do.
Is it even possible to assemble these two pieces using joints? The parts are designed the way they are to be manufactured on a tub cutting laser.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
