Message 1 of 1
Unable to download files using Data Management API+OSS signed S3 url
- Mute
- Permalink
- Report
I am developing a web application wherein I am downloading ACC files via Data Management API and OSS signed URLs stops around 10MB and doesn't complete. The signed S3 URL is generated successfully, but the download stalls.
APIs Used:
- Data Management API v1 - Get file versions and storage location
- OSS API v2 - Get signed S3 download URL
- Direct S3 download - Download file from signed URL.
Code Implementation:
1) Get storage location (Data Management API):
versions_url = f"https://developer.api.autodesk.com/data/v1/projects/{project_id}/items/{item_id}/versions"
params = {"page[limit]": 1, "sort": "-versionNumber"}
headers = {"Authorization": f"Bearer {aps_token}"}
response = requests.get(versions_url, headers=headers, params=params)
storage_location = response.json()["data"][0]["relationships"]["storage"]["data"]["id"]
# Returns: "urn:adsk.objects:os.object:wip.dm.prod/filename.rvt"
2) Get signed S3 URL (OSS API):
bucket, object_key = storage_location.replace("urn:adsk.objects:os.object:", "").split("/", 1)
signed_url_endpoint = f"https://developer.api.autodesk.com/oss/v2/buckets/{bucket}/objects/{object_key}/signeds3download"
signed_response = requests.get(signed_url_endpoint, headers=headers)
signed_s3_url = signed_response.json()["url"]
# Returns: "https://s3.amazonaws.com/com.autodesk.oss-persistent/...signed..."
3) Download file (Direct S3):
response = requests.get(signed_s3_url, stream=True, timeout=(60, 1800))
response.raise_for_status()
with open(temp_file, "wb") as f:
for chunk in response.iter_content(): # Default chunk size
if chunk:
f.write(chunk)I have also tried breaking it into smaller chunks
4) Download URL Code:
def _get_file_download_url(self, file_id, project_id, aps_token):
Get the download URL for a file from ACC using Data Management API
Args:
file_id: The ACC file ID (item ID)
project_id: The project ID containing the file
aps_token: Authentication token
Returns:
tuple: (download_url, storage_location) or (None, None) if failed
try:
# Clean the project and item IDs
# Ensure project ID has 'b.' prefix
clean_project_id = project_id if project_id.startswith('b.') else f"b.{project_id}"
# URL encode the item ID (should already be a URN)
encoded_item_id = requests.utils.quote(file_id, safe='')
# Get versions to find the storage location
versions_url = f"https://developer.api.autodesk.com/data/v1/projects/{clean_project_id}/items/{encoded_item_id}/versions"
params = {
"page[limit]": 1,
print(f"[BACKUP] Getting file versions from: {versions_url}")
print(f"[BACKUP] Project ID: {clean_project_id}")
print(f"[BACKUP] Item ID: {encoded_item_id}")
if response.status_code != 200:
print(f"[BACKUP] Failed to get versions: {response.status_code}")
print(f"[BACKUP] Response: {response.text}")
return None, None
data = response.json()
print(f"[BACKUP] Response data: {json.dumps(data, indent=2)}")
versions = data.get("data", [])
if not versions:
print("[BACKUP] No versions found")
print(f"[BACKUP] Full response: {data}")
return None, None
# Get storage location from the latest version
latest_version = versions[0]
print(f"[BACKUP] Latest version structure: {json.dumps(latest_version.get('relationships', {}), indent=2)}")
storage_location = latest_version.get("relationships", {}).get("storage", {}).get("data", {}).get("id")
if not storage_location:
print("[BACKUP] No storage location found")
print(f"[BACKUP] Version data available: {latest_version.keys()}")
return None, None
print(f"[BACKUP] Found storage location: {storage_location}")
# Extract bucket and object key from storage location
# Storage location format: urn:adsk.objects:os.object:bucket/object_key
storage_parts = storage_location.replace("urn:adsk.objects:os.object:", "").split("/", 1)
if len(storage_parts) != 2:
print(f"[BACKUP] Invalid storage location format: {storage_location}")
return None, None
bucket_key = storage_parts[0]
object_key = storage_parts[1]
# URL encode the object key for the API call
encoded_object_key = requests.utils.quote(object_key, safe='')
# Get signed download URL from OSS (Object Storage Service)
# Use the signeds3download endpoint to get a temporary download URL
signed_url_endpoint = f"https://developer.api.autodesk.com/oss/v2/buckets/{bucket_key}/objects/{encoded_object_key}"
print(f"[BACKUP] OSS endpoint: {signed_url_endpoint}")
# First, let's try to get a signed download URL
# Try getting the object with a signed URL request
try:
signed_response = requests.get(f"{signed_url_endpoint}/signeds3download", headers=headers)
if signed_response.status_code == 200:
signed_data = signed_response.json()
if 'url' in signed_data:
print(f"[BACKUP] Got signed download URL")
return signed_data['url'], storage_location
except Exception as e:
print(f"[BACKUP] Could not get signed URL: {e}")
# Fallback to direct download URL
download_url = signed_url_endpoint
print(f"[BACKUP] Using direct download URL: {download_url}")
return download_url, storage_location
print(f"[BACKUP] Error getting download URL: {e}")
return None, None
Problems:
- Signed URL is generated successfully
- Download starts and progresses
- Stops around 10MB (varies)
- No error thrown; connection appears to hang
- File size: ~78MB
- Timeout set to 30 minutes (1800s)
What I've Tried:
- Increased timeout from 5 min to 30 min
- Tried different chunk sizes (1MB, 512KB, default)
- Verified network connectivity (can access S3 URL directly in browser)
- Checked token scopes (data:read, bucket:read)
Questions:
- Are there known issues with large file downloads (>50MB) from signed S3 URLs?
- Should I use a different approach for large files?
- Are there recommended chunk sizes or timeout values?
- Could network proxies/firewalls interfere with long-running S3 downloads?
