Power Automate does not return cursor (Next page of properties)
Renzo_van_Rijswijk
Renzo_van_Rijswijk
According to the sample you should use the cursor variable to use pagination in your Power Automate flow. So, I have a data exchange with 254 Ducts. When I start the flow and use the "Get properties of object by filter = Ducts" then I get 100 rows of objects. However, the new cursor (token) that should be retrieved in the response is not there (empty).
So when I try to show that in a compose
"Next page of properties" = outputs('Get_properties_of_objects_by_filter_Ducts')?['body/cursor']
The result is empty, and therefor a new call will never be made...
What am I doing wrong? Gr Renzo
Renzo_van_Rijswijk
Finally, I got it to work.... What I did not understand was that you first have to get a cursor via "Get properties of a Dataexchange". Then this cursor is used within "Get properties of object by filter" = Ducts. So in  my case, I got 254 rows in my csv. So I am happy now!
rakesh.borse
 Hello Renzo, Thanks for the update!
