Can't find "Linked Source Revit File" in Power BI through Data Exchange
r_simoes
r_simoes
Hello there,
I'm encountering an issue with the "Linked Source Revit File" parameter within Power BI via Data Exchange.
Previously, after linking models in Revit and exporting them as a federated model using Data Exchange, I was able to find a parameter called "Linked Source Revit File." This parameter was incredibly useful as it identified the original Revit file for each element. This feature was highly anticipated, as the previous workaround involved creating project parameters across all categories in each model and populating them with a key to link elements to their source files.
Upon discovering this improvement, I developed several data-sharing workflows that relied on this parameter, and they were functioning correctly.
However, it now appears that this parameter is no longer available. I'm wondering if this is an isolated issue on my end or if the "Linked Source Revit File" parameter has been removed from the Data Exchange process.
Thank you for your time and assistance.
Best regards.
rakesh.borse
Hello @r_simoes,
We haven't removed this property. It seems our API's hit a regression. The team has started investigating. Hang in there!
Thanks and Best Regards,
Rakesh
rakesh.borse
Hello @r_simoes ,
We conducted an initial investigation of the issue and we working towards the solution. Please hang in there.
Appreciate your patience.
r_simoes
Hello @rakesh.borse ,
My current data exchange, which merges three models, contains a total of 6650 elements. This seems unusual to me, as it's considerably less data than what I was working with a few weeks ago. Previously, the data exchange included structural rebars, formworks for concrete elements, light-steel framing elements, and the architectural model. While I don't recall the exact number of elements at that time, the Data Exchange, particularly the Linked Source Revit File property, was functioning as expected.
rakesh.borse
Hello @r_simoes
We have fixed the issue. Could you please check now? You should be getting the property ""Linked Source Revit File" now.
Please ignore my earlier comment, as after further investigation, we realised that our initial assessment was incorrect — the issue is not isolated to you only and was affecting others as well. Apologies for that.
r_simoes
Hello @rakesh.borse,
I confirm that the issue with my dashboard has been resolved and it is now functioning correctly.
Thank you for your assistance in getting this fixed.
hugo_gouge3BDY9
Hello r_simoes,
I'm trying to create a Power BI report similar to the way you work.
I currently have a central model with several linked Revit models.
I'd like to know how to obtain the "Link Source Revit File" line, as it doesn't appear in Power Query.
Did you create several exchanges that you then combined directly in Power BI?
Thanks !
