- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello there,
I'm encountering an issue with the "Linked Source Revit File" parameter within Power BI via Data Exchange.
Previously, after linking models in Revit and exporting them as a federated model using Data Exchange, I was able to find a parameter called "Linked Source Revit File." This parameter was incredibly useful as it identified the original Revit file for each element. This feature was highly anticipated, as the previous workaround involved creating project parameters across all categories in each model and populating them with a key to link elements to their source files.
Upon discovering this improvement, I developed several data-sharing workflows that relied on this parameter, and they were functioning correctly.
However, it now appears that this parameter is no longer available. I'm wondering if this is an isolated issue on my end or if the "Linked Source Revit File" parameter has been removed from the Data Exchange process.
Thank you for your time and assistance.
Best regards.
