What does C360 form supports from iLogic form today?
I found some posts about this, but they are from 3 year ago.
I have made an iLogic form with rows and pictures. It works and looks good in Inventor 2019.
In C360 everything is there, but in 1 column and the pictures are larger then the 140x140 pixels limit I set in Inventor Form. Is there a way yet to let the C360 form looks a bit more as the iLogic form?
Inventor iLogic Form:
JMGunnar
It only support 1 Column ....
Create one forms for  Inventor and one forms for  C360
and switch too forms in Forms.png Fx
Autodesk  solution - > Embedding website
tolgay.hickiran
Like @JMGunnar said,
You need to use embedding to create custom forms for the web.
C360 is written under Angular and the source code is not open for public usage. They have given us one way to interact with the system using Javascript embedding API. You need to learn generate scripts and code a page in html ( or any other frontend framework ).
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
Thanks for the answers.
We will embed our configurators in a later stadium. But for now it costs a lot of time to discover what works in C360.
Now I discovered that when I put text in a tooltip that it works in Inventor, but the tooltip in C360 keeps showing the standard text.
And now I'm wondering if C360 supports this or not or did I do something wrong?
tolgay.hickiran
You are treating the softwares as if they are the same. You cannot expect the same behavioural pattern "especially" for the forms here. C360 is working under Angular / JS and .NET while inventor is only working under .NET.
The frontend you see on the configurator screen is Angular so the tooltips won't be working.
.NET is a windows framework and changes your "executables" on your machine.
Angular on the other hand is a frontend framework, only working on the web browsers.
Tolgay Hickiran
Founding Partner
SignatureSignature
website
JMGunnar
not supports
only way is too create text parameter + rule thats display info
