Revit Hints & Hacks: Breaking Down Walls
Autodesk Docs Office Hours: Power Tips and Your Questions Answered
Comment (12)
Tips & Tricks are too blasé for me that is why we do Hints & Hacks. Walls are sometimes the first thing we do when starting a project. They do define projects like nothing else. But do you know what they are made of? Let’s break down the wall’s structure, how they interact with each other, how they interact with floors and roofs.
Join us for future Community Conversations!
https://autode.sk/CommunityConvos
Recorded Session:
Labels (1)
Event details
  • Thursday, May 19, 2022
  • 03:00 PM Iceland
  • English (US)
  • https://autodesk.zoom.us/meeting/register/tJwufumrqDgjGddqX1ipAwdNJU4FHgmcTnFS
Featured Guests
Related products
12 Comments
David_W_Koch
The calendar invite says this is for Doors and Windows, not Walls.  Since the June session is also listed as Walls, I assume this one is for Doors and Windows.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
shaan.hurley
Hi @David_W_Koch
Im trying to get to the bottom of this. What calendar invite are you referring to? Is it Zoom or a newsletter? Could you please email me directly at [email protected]
Thank you
Shaan Hurley
Technologist
Between the Lines Blog
@ShaanHurley on Twitter
donnia.tabor-hanson
I really appreciated everyone attending today. My next session is to be Breaking Down Doors and Windows.
https://forums.autodesk.com/t5/community-conversations/revit-hints-amp-hacks-breaking-down-doors-and...
Keep an eye out on the Community Voices channel for me to fix that Stacked wall that I lost. I won't let you down on that one.
https://forums.autodesk.com/t5/autodesk-community-voices/bg-p/voices-blog
Thanks y'all,
Donnia Tabor
CADMama and Revit Family Counselor
Twitter @DonniaTH
LinkedIn
@donnia.tabor-hanson
Not sure if anyone attending "live" responded in the comments regarding a session on Curtain Walls, but I would be interested in one.
David Koch
Blog | LinkedIn
I think that is a natural follow up session. I will schedule it @Anonymous for sure
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
shaan.hurley
A recording of the session has been posted.
https://youtu.be/RXiNXNIpuIM
Helpful Links
Autodesk Community Conversations:
Autodesk Group Network:
https://knowledge.autodesk.com/community/groups#/overview
Architecture Engineering & Construction Community:
https://www.autodesk.com/community/architecture-engineering-construction
Design & Manufacturing Community:
https://www.autodesk.com/community/design-manufacturing
Media & Entertainment Community:
https://www.autodesk.com/community/media-entertainment
Autodesk Forums:
Autodesk Community on Twitter:
https://twitter.com/ADSKCommunity
Autodesk Community on Facebook:
https://www.facebook.com/autodeskcommunity
Autodesk Community on LinkedIn:
https://www.linkedin.com/showcase/autodesk-community/
Autodesk Community Journal blog:
https://blogs.autodesk.com/community-journal/
Autodesk Community Voices blog
A blog by the community, for the community.
It’s your place to connect, share, and learn with the community. The blog will feature product tips, workflows, articles, updates, and more, all shared by members of Autodesk’s global community.  Blogs can be found here.
If you’re interested in being a blog post author on the Autodesk Community Voices site, please complete the questionnaire found here.
Community Conversation Proposal link:
https://autodeskfeedback.az1.qualtrics.com/jfe/form/SV_6ofmUCJ943S4BBI
Shaan Hurley
Technologist
David_W_Koch
Question regarding the Align tool with Walls.  I am seeing the initial alignment options as Exterior Face, Centerline or Interior Face, not Location Line (unless the Location Line happens to be at one of those, of course).  If I hit the Tab key, then I can choose either face of any component, or the centerline of the core.  Was the exterior face of core in your example Wall Type at or close to the Wall Centerline?  Or am I doing something wrong?
David Koch
Blog | LinkedIn
@David_W_Koch you may be over thinking this. I probably did Core Face: Exterior because that is my go to. Here are the Location Line options. Not one is named Location Line.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Understood.  In the presentation (started watching the video today), you demonstrated using the Align tool on the Wall, and indicated that the initial choices for alignment were at the faces of the overall Wall or at the Location Line (which will be one of the options shown in your image).  In a test model, I was seeing the initial choices as being the faces of the overall Wall and the centerline of the overall Wall.
In the Wall Type I was using, the Location Line was set to Core Face: Exterior, which did not fall at the overall Wall centerline.  I had to select the Tab key to get the Align tool to allow me to select Core Face: Exterior.
Since it looks like the initial choices for the Wall in the video were faces of overall Wall and the Core Face: Exterior (to which the Location Line was set), I was wondering if your Wall just happened to have the Core Face: Exterior fall on the Wall's centerline (or sufficiently close that you cannot see the difference in the resolution of the video), or if I was missing something that would allow the Location Line to be an initial choice, without using the Tab key, if it was not at the faces or centerline of the overall Wall.
David Koch
Blog | LinkedIn
I see, as far as I can tell you have to tab through to get core face. It is like there is a hierarchy that you have to pass through to get to the core face exterior. Center of wall is hardly ever a good choice unless your wall is layered symmetrically.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
donnia.tabor-hanson
As promised, I am covering how to build a stacked wall in my blog post. First, I had to finish a series on Revit Arrays, that turned out to be a good one. Here is the post on the Stacked Wall.
https://forums.autodesk.com/t5/blogs/blogworkflowpage/blog-id/voices-blog/article-id/357
In the next Community Voices I will be covering Hints and Hacks: Breaking Down Doors and Window Families where I will be covering a bit of a problem with stacked walls when it comes to placing doors and windows in them. Join me for that one.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
donnia.tabor-hanson
As an Autodesk Exert Elite, we are asked to rag our post with #AutodeskExpertElite. Catching up now.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
