Revit Hints & Hacks: Curtain Walls and Ways to Use Them
Autodesk Docs Office Hours: Power Tips and Your Questions Answered
Comment (8)
Curtain Walls are not as difficult as they may seem once you get to know how to use them.
They can be used in so many ways:
Used as store front, rails, walls, tilt-up walls, and even wall décor.
Let’s break down some ways to use these.
Labels (1)
Event details
  • Thursday, January 26, 2023
  • 08:00 AM US/Pacific
  • English (US)
Featured Guests
Related products
8 Comments
donnia.tabor-hanson
For Curtain Walls I got a lot going on. I have 10 examples of Curtain Wall that I will be showing. Railing, Roof, Wood Timber, Louver, Spider Exterior Glazing, Revolving door, manufacturer sites, tilt-up wall, massing shape wrap, and wall decoration. Also short cuts for manipulation of the pieces and parts. Gonna be a good time.
Thanks y'all,
Donnia Tabor
CADMama and Revit Family Counselor
Twitter @DonniaTH
LinkedIn
It always is.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
shaan.hurley
Why did the roof designer go to the doctor?
They had a bad case of the shingles.
Shaan Hurley
Technologist
Between the Lines Blog
@ShaanHurley on Twitter
Groan
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
donnia.tabor-hanson
The Links from class
Spider Clip
https://www.modlar.com/profile/145201/piklu-s/spider-clip-curtain-panel/
Manufacturer sites
https://static1.squarespace.com/static/5605a932e4b0055d57211846/t/6330e3b7f54d2b5589af6d61/166414840...
https://www.kawneer.com/kawneer/north_america/en/bim.asp?prod_id=1816
BIM Object
https://www.bimobject.com/en
Massing Video
https://www.youtube.com/watch?v=z_iBVx1lSs8
Wild Brick Curtain Wall
https://www.autodesk.com/autodesk-university/class/Dynamo-Curtain-Panels-Wild-Brick-Pattern-Workflow...
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Sol Amour mentioned that in the UK they can place faux bricks in walls for birdhouses.
https://www.wired.com/2013/07/these-bricks-are-made-for-birds-to-nest-in/
Shaan Hurley
Technologist
That is so cool
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
donnia.tabor-hanson
For those that attended, I found the corner option to fix the corners. I posted it in my blog on the Autodesk Community Voice.
https://forums.autodesk.com/t5/autodesk-community-voices/revit-hints-and-hacks-curtain-wall-corners-...
#AutodeskExpertElite #CADmama #Revit #Curtainwalls
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
