- Mark as read
- Mark as new
Join Jacob and Sol for How to Make Dynamo Sing!
Do you want to understand how Dynamo performs under the hood? Do you want to know all the levers you can pull to make Dynamo perform as fast as it can? Do you want to geek out and talk all things technical in Dynamo? Then come join Jacob and Sol as we dive into the worlds of execution, tessellation, rendering, marshalling and compliation! And if all that stuff sounds a little too much, then don’t worry as well leverage metaphor and storytelling to explain what matters and how you, as a user, can interact with Dynamo to get all that you can out of it! We’ll explore both Settings and node based options to make your Dynamo graph sing, as well as exploring display options, discuss inline vs. multi-line functions and what function passing is, and refresh on delta-compute and how it helps graph execution.
This session will be also be supported by an Autodesk Community Manager as part of Community Conversations - live, virtual events designed to allow you to gain expertise, connect with leaders and grow your community network.
The Recorded Session:
To learn more about Autodesk Community Conversations, including how to become a presenter, find more information here: https://forums.autodesk.com/t5/community-conversations/welcome-to-community-conversations/td-p/10167...
- Thursday, November 18, 2021
- 10:00 AM PST
- English (US)
![Alumni Alumni](/html/@EA371A9DAF7A54A6A36FF28C7325BA2E/rank_icons/alumni.png)
![Autodesk Support Autodesk Support](/html/@99F3A8ED16C4FAC9A1252261FC946355/rank_icons/employee.png)
