Intro to Autodesk Construction Cloud Modules
Connected Construction using Autodesk Construction Cloud
Communication within a team can happen through various formats, including paper. Actually, more than 70% of the global construction industry is still working from traditional paper-based processes.
This issue has an added layer of complexity when we consider the communication between different teams.
We are delivering best-in-class capabilities to enhance collaboration through meaningful workflows for all phases of construction. From Design Authoring to Facilities Maintenance, we are integrating workflows to enable construction teams to optimize desired outcomes while ensuring construction companies expand their businesses.
All of this is only possible through a strong, connected foundation: With Autodesk Construction Cloud, shared data allows assertive decision-making and enables predictive insights. Documents are shared, so work happens from the single source of truth. All this gathered data enables construction teams to better deliver and even predict business outcomes.
Autodesk Construction Cloud Products :-
Autodesk Docs
Is the Common Data Environment CDE that connecting different project stakeholders from Contractor ,Subcontractor and consultant....etc.
Autodesk Collaborate Pro
In Autodesk BIM Collaborate Pro, we focus particularly on design collaboration and model coordination.  Design collaboration focuses on sharing information in a controlled manner, throughout various teams.  Whereas, model coordination focuses on the aggregation of models for the design coordination processes and automates clash detection.  In both products, you can communicate through issue management, and you also have that base of collaboration through the cloud with Autodesk Docs.  In the last year, Autodesk developed change analysis, which helps inside design collaboration to focus on what is changing in the project.  Together, these products focus on the design and coordination phases.
Autodesk TakeOff
Autodesk Build
When armed with Autodesk Build, teams can overcome many of the challenges faced by the industry today.
Autodesk Build delivers a broad, deep and connected set of field execution and project management tools for builders in a single software platform that is easy to deploy, adopt and use.
Build provides an environment where information sharing and workflows are both tightly-controlled and highly-configurable.Let’s take some time to look at all of the capabilities and the workflows supported. First, Document Management.
Useful Links:-
Autodesk Takeoff
Autodesk Build Module
Elmoataz Bellah Salem
Autodesk Certified Professional for Revit Structure and for Civil 3d and also Autodesk Certified Instructor with GIS Background and BIM Experience and I am working as AEC Technical Specialist for SYTEQ Corporation Autodesk Gold Partner in Egypt.
LinkedIn
3 Comments
