Level: Intermediate
Recorded in: Autodesk Flame Premium 2017 Extension 1 (2017x1)
In part 5, we discuss Substance PBR which can create procedurally generated textures that can work within the Physical Based Shading model.
So if you don’t have a texture and don’t have time to manually create your own, you can use procedurally generated textures to quickly generate a texture that can be used on any 3D objects in the composites.
Allegorithmic Resources:
- Substance Database: https://www.allegorithmic.com/products/substance-database-monthly
- Substance Source: https://source.allegorithmic.com/#/substances/home
- Substance Share: https://share.allegorithmic.com
For More Information, Feedback and Comments:
Autodesk Area
http://area.autodesk.com/learning/resource/flame
Facebook
http://www.facebook.com/AutodeskFlame
Twitter
@Autodesk #AutodeskFlame
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
