This article is a translation of the original text HERE.
This article briefly describes how to find your own Python files and decompile them using third-party tools.
- Find the built-in Python file
Taking AutoCAD Plant 3D 2025 as an example, the corresponding parametric drawing file is under the installation path:
C:\Program Files\Autodesk\AutoCAD 2025\PLNT3D\ContentScripts
- Unzip the file
Unzip the files in the variants.zip zip package
- Find the cpb.pyc file
varmain\arcsub\cpbsub
- Use a third-party website to decompile PYC files
- The result of decompilation
#!/usr/bin/env python
# visit https://tool.lu/pyc/ for more information
# Version: Python 3.11
from aqa.math import *
from varmain.arcsub.cpb_util import *
from varmain.primitiv import *
from varmain.var_basic import *
def CPB(s, D, D2, R, L2, L1, A, OF, ID = (114.3, 0, 175, 0, 0, 90, -1, 'CPB'), **kw):
if R <= D / 2:
R = D / 2 + 0.0001
if D2 <= 0:
D2 = D
o0 = ARC3D2(s, D = D / 2, D2 = D2 / 2, R = R, A = A)
Pts = CPB_CalcPts(o0, A, None, None)
a1 = Pts[1]
a0 = Pts[0]
Pts4 = Pts[4]
Pts5 = Pts[5]
Pts6 = Pts[6]
Pts7 = Pts[7]
Pts = CPB_CalcPts(o0, A, L1 + a1 - a1, L2 + a0 - a0)
HLeft = L2
HRight = L1
if HLeft <= R:
Pts[5] = Pts5
Pts[7] = Pts7
HLeft = R * 0.01
arc3d2TMP = CYLINDER(s, R = D * 0.01 / 2, H = R * 0.01).rotateY(-90).translate(Pts[8])
arc3d2TMP.uniteWith(o0)
o0.erase()
o0 = arc3d2TMP
else:
arc3d2TMP = CYLINDER(s, R = D2 / 2, H = HLeft - a1).rotateX(-90).rotateZ(90 - A).translate(Pts[9])
o0.erase()
o0 = arc3d2TMP
if HRight <= R:
Pts[4] = Pts4
Pts[6] = Pts6
HRight = R * 0.01
else:
arc3d2TMP = CYLINDER(s, R = D / 2, H = HRight - a0).rotateY(90).translate(Pts[8])
o0.erase()
o0 = arc3d2TMP
OF = getThickness(D = D, OF = OF)
if OF > 0:
O1 = getInsideDiameter(D = D, OF = OF)
O2 = getInsideDiameter(D = D2, OF = OF)
o1 = ARC3D2(s, D = O1 / 2, D2 = O2 / 2, R = R, A = A)
o0.subtractFrom(o1)
o1.erase()
s.setPoint(Pts[4], Pts[6], 0)
s.setPoint(Pts[5], Pts[7], 0)
activate(CPB, '\n[Type AQA-VCPB]\nVID=STRING,32\nDN=STRING\nD=LENGTH\nD2=LENGTH\nR=LENGTH\nA=ANGLE\nOF=LENGTH\nUnits=STRING,8\n;\nuniqId=CALC =$self.VID$ $self.DN$ $self.D2$ $self.A$\n;\nboltCalcVal=CALC CPB_GetNeededBoltParam(B1=0.0, B2=0.0, L1=-2, L2=-2)\n;\n@key=VID,DN\n', '@VarDataDefault0')
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
