& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Regional Rollout of One-Time Passcode via Email for All Autodesk Customers Begins April 2, 2025
We are committed to ensuring the security of Autodesk customer accounts. As part of this commitment, we will implement a one-time passcode (OTP) verification via email for all Autodesk customers starting April 2, 2025. Using OTP is a form of multi-factor authentication (MFA) that provides extra security for your Autodesk accounts and deters unauthorized access.
What to Expect: Starting April 2, we will begin our rollout of the enhanced email OTP workflow. This rollout will be conducted gradually, region by region. Once we enable this feature in your region and unless you otherwise have SSO or MFA enabled, you will need to use it as part of the verification process to access Autodesk products. Upon entering your username and password, you will receive an OTP via email, which you must provide to complete the verification process.
Key Details:
Thank you for your cooperation and commitment to maintaining the security of your Autodesk accounts.
Additional Information
Why use Multi-Factor Authentication (MFA)? Security threats are increasing and becoming more sophisticated, making robust protection more critical than ever. As companies in the make and design industries, including Autodesk, rely more on digital infrastructure, protecting sensitive data and maintaining system integrity becomes paramount. Enforcing MFA is an effective way to enhance security.
Email OTP verification Email OTP verification is one of the many strategies used in MFA. With this method, after you enter your password, we send an OTP to your registered email address. You must enter this OTP to complete the login process. This adds an additional layer of security because even if someone knows your password, they would also need access to your email account to obtain the OTP.
What’s in it for me? Here’s why we at Autodesk are enabling email OTP, as a form of MFA, and why this will benefit you, as a customer:
Frequently Asked Questions (FAQ)
Q: What is Multi-Factor Authentication (MFA)?
A: Multi-Factor Authentication (MFA) is a security measure that requires you to provide two or more verification factors to gain access to accounts or system. These factors typically include something you know (password), something you have (a smartphone or hardware token), and something you are (biometric verification).
Q: Why is MFA important for customers in the make and design industries?
A: MFA is crucial for protecting confidential data and intellectual property in the make and design industries. It provides an additional layer of security, reduces risk of unauthorized access and mitigates the impact of credential theft.
Q: How does MFA help in complying with industry standards?
A: MFA helps Autodesk and customers comply with industry regulations and standards that mandate strong data protection practices.
Q: What are some common methods of implementing MFA?
A: Common methods of implementing MFA include email-based verification, mobile authenticator apps, hardware tokens, and biometric authentication (e.g., fingerprint or facial recognition).
Q: How does MFA protect against phishing attacks?
A: MFA adds an extra layer of security by requiring multiple forms of verification. Even if you fall victim to a phishing attack and your password is compromised, the attacker would still need the additional authentication factors to gain access, making it much harder to succeed.
Q: What are some best practices for implementing MFA?
A: Best practices for implementing MFA include:
Your links do not work
Thanks Curtis. Updated section into content instead.
Thank you for the advanced notice.
Christopher Stevens
2FA/OTP from phone apps(MS, Google etc..) will be available?
Correct. All users who do not currently have SSO/MFA enabled, will be required to use the enhanced verification workflow on cloud, desktop, and mobile applications.
I find it interesting that customers/users folks logging in are held to some rigid access procedures like the ones described here. when truth be told the unauthorized access or hacking doesnt happen from the log in page, or from our side, its from the other side. Breaches of data are almost common place now. Not specificlly Autodesk, but other vendors, AMAZON, BANKING,,,,
What is the order of regions where the rollout will take effect?
And will the email verification be necessary with each login?
I know little about security so my question might be naive. Why can't you use text like so many other companies do? Or give us the choice.
You can choose that option if you set up 2 factor authentication yourself, the measure is for people who have not set up 2-factor authentication.
@tcorey I apologize, I just tried it myself and apparently the authenticator app is the only option atm?
Valid point @ParishSouthBdx. MFA (including OTP) still can be part of a comprehensive security strategy. While we cannot prevent against all type of security breaches, we believe MFA is a crucial part of a multi-layered security approach that helps protect against a wide range of threats. It's not about burdening users with rigid access procedures but rather about safeguarding their data and maintaining the integrity of the systems they rely on.
Please reach out via https://www.autodesk.com/support/contact-support
Will we be required to go through the OTP email exercise each time we start/restart an Autodesk software product on our computer? I admit my confusion over the "one-time" part of "one-time passcode"; it may have multiple interpretations. Is it one-time use, or one-time required? I don't normally keep Autocad and Revit open simultaneously, and bounce back and forth between the two frequently, and not looking forward to waiting on emails each time I want to swap. So an additional question: will this cause issues if we do run multiple Autodesk products simultaneously? By that I mean both multiple instances on the same computer of the same product (like 2 instances of Autocad), and running both Autocad and Revit on the same computer.
Thank you for your comment @dsummersPEG.
This doesn't apply to me. But, I remember issues from previous license changes. Is there any thought being put to users that have to work out of contact with internet services or those working in disaster areas where cell phone services have been disrupted?
Allen Jessup
CAD Manager - Designer
@AllenJessup Pre-planning and seeking out Autodesk Licensing 'special needs' need to be planned for ahead of time. For everyone else, I suspect Starlink (and others soon enough) is a modern solution and is good enough to use once a month for your laptop to call home for a license check before letting you work remotely again.
SO... If you have power (aka electricity), today's excuses for no internet access have been reduced dramatically.
@pendean Understood. And for the once a month check in I'm sure that would be fine. However I could see having to get an email every time you open a program may cause some people an issue. I've never used Starlink so I have no idea how it may perform worldwide.
Heck. Our MFA service went out for over half a day. After an hour or so IT had to disable it so people could log in to there computers. The week before our phones (VOIP) went down for a couple of hours. Those who only had MFA through their office phones were locked out.
Allen Jessup
@AllenJessup wrote:
... Those who only had MFA through their office phones were locked out.
Yes, and probably related to the recent push by Autodesk to offer email OTP instead: other software vendors have it, its not limited to phone numbers, and I am a total fan.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
