Walls as grading objects in Grading Optimizer
To summarize below: Adding vertical objects with customization settings would be useful for site grading in Grading optimizer.
Being able to use a retaining wall (or similar site grading walls) would be useful for being able to see how tall a wall would need to be in order to achieve the site grading targets. Allowing for the following criteria/settings would make this a useful tool:
  • Height
    • Minimum Height
    • Maximum Height
    • Consistent height (check or uncheck)
  • Wall Width
  • Elevation
    • set top elevation or set bottom elevation
      • bounded value or one set value.
1 Comment
TimYarris
Status changed to: Accepted
Thanks for the suggestion. Retaining wall support is high on our list of enhancements for Grading Optimization.
