Profil sewer pipe
Profil sewer pipe
Will it be better if we can select a profile pipe and change his size without entering the pipe properties? It's already possible when we select it in plan view.
4 Comments
TimYarris
@jerome.raby, would you please let me know where you would expect to change the pipe size in either plan or profile? Are you recommending the AutoCAD Properties panel for this?
jerome.raby
@TimYarris , when we right click the pipe in the profil view there's no option to change the diameter except to enter in the pipe property. But when we do the same operation in plan view, i right click on my pipe and there's an option to change the diameter. I shared to screen shot of both panels.planview.pngprofileview.png
TimYarris
@jerome.raby , so it is the Swap Part command you would like to see in the profile right-click menu? Here is my menu in Civil 3D 2022:
jerome.raby
@TimYarris yes its the swap part command that i want in the profile right-click menu.
Answer Day
Rail Community
