FDS has new discoveries in turnkey engineering design construction methods that automates and manages complete construction and as-built packages with GIS database management. How could Autodesk better serve the construction world? Well, they first have to better understand what the full parameters are for centerline route projects. From oil & gas pipelines, to waterlines with septic & fresh, to transportation with highways, to railroads and terminals, to electricity with utilities-fiber optic-5G, power lines, towers and power poles and waterway embankments. All these projects have one thing in common, they require a full engineering design construction package, environmental mitigations, right-of-way acquisitions, survey field to finish process, inspections for accountability and government permitting for complete build-out.
First thing you have to do is design FERC alignment sheet drawings for permitting processes and you still have PHMSA, DOT, DOE, ArmyCorp and RRC government agency submittals and permits to file before project build-out. Even when your project is completed, the owners still have to pay for a survey as-built package for internal compliance and more government agency deliverables. From conceptual, preliminary, construction, as-built to compliance processes, the owners built there projects several times.
Wouldn’t it be nice if there was a full platform tool that automates this for you? Now there is with our new mapper suite platform that automates and manages complete project lifecycle data management. You will have advance business development tools for project reporting and project management, next level design tools to automate your complete engineering design construction and as-built packages with all your CAD drawings: survey master, 8.5x14 plats, 24x36 alignment sheets, 8x11 permits, 24x36 directional drills, 24x36 integrity sheets, 24x36 site plans, plot plans, traffic control maps, weld maps, GIS maps, cover sheet and others.
At the end of the day, you want the best efficient means for your projects. The Mapper Suite 2D-3D supports Autodesk C3D and Cloud Software’s. The mapper suite will save your projects lifecycle time and money. Find out more at Forefront Design Specialist.
