Selective Surface Paste
The ability to paste a surface only where it is above or below another surface would be very useful for my workflows. It is possible to do this manually but it is very tedious and long winded.
2 Comments
FrankBellekom
I have this same problem and it's a hell of work to do this with comparison and boundaries.
peterfarkas
I agree, this would be a super useful feature. Sometimes it takes quite an effort the smooth surfaces together.
For example when modeling pipe trenches I need to always manually generate the intersection lines and cut surfaces, otherwise when pasted together the intersections are a mess.
Could be a negative paste where things are excavated and a positive paste where things are piled onto and keep the normal that is both.
It shouldnt be hard to implement. If I would be programming this I would take the points from both surfaces, generate a volume surface and I would use the volume surface to determine at each location which surface to the elevation from. For excavations for example wherever there is no volume surface, use EG, where the point elevation is positive, take EG elevation, where it is negative, take DG (degisned) elevation.
Please add this feature. Should be so easy... So difficult to model complex foundation pits and pipe trench crossings.
