Show only
Search instead for
Make sure there is a way to extract a solid from the surface so that when we use the object viewer to visualize the surface the lines do not appear. In the same way this can be done with the view of the corridor.
Thank you for your idea. Does the ExportSurfaceToSolid command meet this requirement? If not, would you please let us know what else you are looking for?
