superelevation table for straight alignments
hello,
there should be a possibility to enter superelevations for straight alignments. Sometimes we have alignments consisting only of two points (straight line, no curves). The only way to add superalevations in the superelevation table (Querneigungs-Editor) is to add a curve, so we could enter superelevations at specific stations.
Thank you.
4 Comments
TimYarris
Thank you for your idea. This can be done using a User-Defined Curve. Would you please review that help link and let me know if that resolves this issue for you?
ralf.kuennemann
Thank you, the problem is solved with this. It's not obvious that you need to use this function to create superelevations for just straight lines.
ralf.kuennemann
Thank you. That solved our problem. It's not obvious that you need to use this function to create superelevations for just straight alignments.
TimYarris
Rail Community
