station lists
station lists
There should be a possibility to save station lists for later use.
Example: create detailed stations for the corridor for a high resolution 3D model, but for normal use a lighter station list for a better performance. Once you have created the detailed station list you should be able to save and restore this list and use it also for other purposes like labeling etc.
3 Comments
joantopo
There are some topics related to this. I think I called "Corridor Frequency style" years ago.
joantopo
https://forums.autodesk.com/t5/civil-3d-ideas/corridor-region-frequency/idi-p/9595723
Civil 3D introduced Corridor Template but is not exactly the same....
TimYarris
Thank you for your idea. We're researching a variety of ways we might make corridor modeling more performant for different phases of design. Here's an example:
https://portal.productboard.com/jepvxreqkffwuku66cnkvxke/c/110-corridor-level-of-detail?&utm_medium=...
