Subassembly composer - turn of xaml file update
The rebuild of the xaml file take long time when I create complex subassemblies.
My backdoor is to break the schema and editing a bunch of objects after the break, then connect the schema again to test and fix whats needed.
When the schema is broken I´m not able to change point and links in drop down menus since the schema is broken.
It would be nice to have the possibility to change those based on the last full rebuild.
Can the be solved with a turn of rebuild button, so that i can build things fast (in memory) and then turn on the rebuild again...witch then save to xaml and show the result in the preview window.
Then i dont need to wait for the rebuild on each single change.
1 Comment
TimYarris
Hi @magnussvensson ,
This idea aligns with two areas we have under research:
  • Enhancements to Subassembly Composer
  • Improvements to the overall performance of Civil 3D and its companion tools
We will keep you informed of our progress.
Rail Community
