Currently, corridors sections or suface sections can be changed to Static (instead of Dynamic).
I would like the same for Section View objects. This way, if I remove Sample Lines or the parent alignment, Sections Views are retained.
I say this because I erase a lot of objects to be able to export a Civil 3D drawing to AutoCAD due to the machine needs a lot of resources to export the drawing.
Generally, I only want to export Section Views to AutoCAD dwg.
