Chained Table Tag Renumbering Command
 When renumbering Table Tags, the command must be executed again for each tag. Chaining this action, (much like drawing a polyline) would reduce this process significantly.
If the command line also prompted for the beginning line and curve numbers, it would eliminate the need to open the annotation command, navigate to line and curves, and select the Table Tag numbering window.
