shifting text in plan view
Can some one really tell me (i do mean doctoraial thesis explain) why text shifts in profile views? i have attached a model space and paper space image of the the same profile, and WHY is going on with the text shifiting?
5 Comments
doni49
You'll get better responses by posting this in the C3D forum.  This area is meant specifically for submitting feature requests for future versions of C3D.
EDIT:  I meant to include a link to the forum.  http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
Hello
and thank you for the response
I personally think this problem NEEDS to be addressed in future versions of C3D.
Or at least put in a patch the corrects the problem.
Sorry that you do not see the problem.
C13
Charles A. Hall, E.I.T.
Civil Designer
CARLSON, BRIGANCE, & DOERING INC.
CIVIL ENGINEERING & LAND SURVEYING
5501 WEST WILLIAM CANNON DRIVE
AUSTIN, TX 78749
PH: 512-280-5160 X123
FAX: 512-280-5165
doni49
The big difference I see between your two images is the text SIZE is different between them.  And the size difference could cause them to appear to be "shifted" as you say.
That is not a bug -- that's an operator that doesn't understand the program.  Post the problem in the discussion forum and someone will help you understand what's going on.
Please look, and I do mean look at the two images
Yes, the text size is different
And shifted to the left in the one image.
Next time I will clip my images to just the area of interest - the entire plan view in paper space and the exact same area in model space
This IS a program problem !
Please check the text and images again.
Thank you
Civil Designer
AUSTIN, TX 78749
FAX: 512-280-5165
doni49
Ok.  I finally see what you're talking about (and yes cropping the image and/or somehow annotating it would have been very helpful).
I'm still not totally sure there's not something going on in the file itself and would like to look at it which will require posting in the forums.
