キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
このページは利便性のため、翻訳システムによって自動的に翻訳されています。正式な翻訳として提供されるものではないため、不正確な翻訳が含まれる場合があることをご承知おきくださいオートデスクは、機械翻訳システムによって翻訳された情報の正確性、信頼性、完全性について、明示または黙示の別を問わず、一切の保証を行いません。また、お客様が機械翻訳システムを信頼することで生じた損害または損失については、いかなる責任も負わないものとします。 翻訳
See where Subassembly is used
I would like to be able to quickly see where each subassembly is used. At a minimum, be able to see which corridor is is used in. A bonus would be to right click and and have it highlight the regions it is being used in.
6件のコメント
joantopo
I think that is strongly necesary some command (or perhaps a new tab in the assembly properties), to list all the Regions (of all Corridors) that they are using that assembly.
If it was a command (choose the assembly by picking in the drawing or by a list), and a combobox filter (about corridor).
I am scary every time I have to modify some assembly because I don´t know if that assembly is being using for another Region and it can´t change some parameter of the subassemblies. In that case, I had to copy the assembly to create a new, but I am not sure if it is necessary.
We could check the "parameters" tab of the corridor form, checking each Region if it has assigned that assembly, but it is a lot of work to do that.
(Now I have a corridor with more than 30 regions...) so it was crazy checking their assemblies every time.
joantopo
I reaffirm that a new tab in the assembly properties form would be best.
undefined
joantopo
In my app (addon), I did a command in which you could select an assembly in the drawing and then the command list all references (Corridor name, BaseLine name and Region Name) in the command line, checking each corridor region in the drawing.
I think this would be also feasible for subassemblies.
In my opinion, if we select an assembly or subassembly in the drawing (or in the ToolSpace), the context menu of that object should show us "References..." option to get a list, similar than currently we can do with styles.
I proposed another type of command:
Where you can pick a point on a corridor and then according to the picked point you can open the respective assembly properties dialog box.
(in fact, is the reverse of your proposed idea).
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/zoom-to-assembly-selecting-a-corridor-region-i...
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/references-dependencies-of-the-assembly/idi-p/...
joantopo
Another option is the corridor properties has a "Summary" tab where it is listed the names of the used assemblies and the used subasssemblies.
TimYarris
変更されたステータス: Accepted
This idea is under consideration for a future version of Civil 3D. Please visit the Autodesk Civil Infrastructure Product Roadmap for details and to vote for this idea to indicate its importance relative to other items that are under consideration.
TimYarris
@Michael_McKeon , would you please let me know whether new Subassemblies tools in Project Explorer satisfy this requirement for you? If you open PE and go to Subassemblies tab, pick a subassembly, and go to the Associated Corridor Regions tab, it'll show you the corridor and region associated with the subassembly.
アイデアを提出
Rail Community
