When I work in SAC with "Get Marked point", I am programming as a blild.
If another subassembly has several "set marked point", for example to define 2 points to determine a slope, then I can´t recreate that scenario (slope) in my current subassembly using "get marked point" (typing the same marked name), due to SAC throws the report message about Marked point does not exist.
Ok. It does not exist, but if I add temporary a "set marked point" as the first element in the current subassembly (with that marked point), I can´t either remove that report message.
What I want to mean is that I would like to add "set marked points" in the header of my subasssembly to check my subassembly and finally I could disconnect that "set marked points" to save my PKT file.
Currently, we can´t do this because SAC doesn´t recognize the same set and get marked point in the same subassembly (in SAC)
